BIGRED74K20
Registered Member
The truck is a 1974 k5 blazer 350, sm465/203, factory AC. When I brought this home I never drove it to see if it ran on the hot side. Shortly after I converted it from manual to automatic (TH400/205) and swapped in a D60/14bolt. I kept the 350 in the truck with the AC and the only thing I did was remove all of the California emission crap and put headers on it. Reused the 3 core radiator that was in there for the transmission cooler.
About 3 weeks ago as I started to finish everything up on the truck, I flushed the cooling system, drained and filled it (60/40) water coolant ratio, installed new hoses and a 195 thermostat. Started the truck with heater on, added coolant as it needed and made sure all the air was out of the system. As it was idling the truck got up to 200, 210, 215 then I shut it off. Let it cool a little bit (took awhile) then took it for a short drive around the neighborhood, went a 1/4 mile and by the time I got back it was pushing 225.
Next morning I removed the thermostat, started it up and it immediately ran cooler (180) I then took it down the highway and it got back up to 210/215. So cruising down the highway did not lower the temperature whatsoever, only stays idle.
After this I checked and made sure that the lower hose wasn't kinked, thermostat was good and that the coolant was flowing through the radiator tubes (flowing pretty good) Next morning I started it and let it idle and sat at 200 degrees.
Next I pulled the water pump and it looked to be good/new condition. Replaced the water pump with a HD pump and reassembled everything (left stat out) Ran the truck and it didn't make a difference. Ran a infrared thermometer all along the radiator while it was running and it read a consistent 110-120 top to bottom with no cool spots.
Tried a universal temp gauge just to rule out the factory gauge and very little variation in temperature...
Any ideas or leads would be greatly appreciated at this point
Thanks in Advance!
Thanks in Advance!
