Looking for rust free/dent free tailgate snd corresponding hardware. Prefer 70’s (75-80) style but will consider 80’s style.
From 1975 up to early 1976 had the 1st design shown as the 73 and 74, but had a different system to remove the tail gate easily without removing the trunion. Then in late 76 model year the went to the 2nd design as shown for 75-80. If you have a 75 or 76, you should have a rectangular hole in the end of your bed side.Preference is 75-80, thank you for helping clarify! I missed that 73/74 had their own setup. Goal is to run the thin cheyenne band, which fits 75-80 if i read correctly (can work with 81+, but not a clean fit). This will go onto a k5
Up to later 76 had the slot that went into the end of the bed side. With a different trunion made it easier to remove the tailgate!I post all of that because you may want to avoid the 73-74 style unless you are willing to cut the slots in your bed sides.
