what would be the best method to get a mechanical speedometer to work with a np242 transfer case that came from a '98 H1? the 242 uses a VSS to transmit speedometer signal to the gauge cluster.
i was just wodering if anyone knows of a way to adapt a mechanical speedo cable to a late model transfercase?
or would i just be better off using some sort of aftermarket gauge that can use the VSS signal?
