dailyk5
Registered Member
im trying to sell a 1975 k5 blazer. this truck is in very good shape. it was repainted about 4 years with new rocker panels and rear wheel openings and a whole front clip. it also had a new interior put in at this time as well. the floorboards in this truck were very solid, the bed has no rust at all and the front floors had some surface rust that i put fiberglass over and only one quarter sized spot that i cut out. the motor is the original 350 and has about 20000 miles on it since a rebuild. it has a turbo 350 that i do not believe is rebuilt but shifts real nice and smooth, no slips. the only real performance modifications done to the motor was an aluminum edelbrock intake, holley carb, and headers. it also has a nice flowmaster exhaust (super 44) that was put on about the same time it was painted. the only bad part of the paint is where rust is starting to bubble the paint at the door corners. i have two rust free doors off of a 79 chevy truck that go with it to fix this problem. the drivers side window regulator works but the bearing for the handle is very loose and i have a new regulator that will go with the truck as well. the back window regulator is new and will roll down but i think one of the tracks are broken to where the window will not stay level. im sure ive forgotten some things and i will post more pictures but it is raining right now and this is the only onw i have. i will take some more when it clears up. im asking $5000 nego. for it. let me know if youre interested. thanks
This post is almost 4 years old!
