75 steering knuckle on a 89
yep tehy will work. you have flat knuckles (73-75 d44's only), with are what you need for cross-over
It'll fit, but I'm 99.9% sure that you'll have to install old knuckles on both sides or the tie rod won't fit. Seems to me like you also have to get a Dana 44 tie rod to match the "new" old knuckles.
yes ull be both of the knuckles from the same axle or they wont work, well the tie-rod will be crooked
it's not a dd, the frame's bent, and i aint really concerned with allignment. so i guess my question is, will it function? with just one?
thanks
evan
thanks
evan
It will function, but I don't think it would really be safe. One knuckle the tie-rod will mount on top of the steering arm, and the other will mount underneath. If you are goin hi-steer it shouldn't matter, but I think with the tierod crooked like that it will prolly be hard on one or both TRE's. Just my .02 it's your steering do it right.
