digitalepiphany
I posted this in the 73-91 technical discussion forum before I realized there was a dedicated engine swap forum. So, if any moderator wants to delete the other one, it'd be much appreciated.
How difficult would this be to do? I'm sure it's not a straight drop-in, but I'm still crossing my fingers. I believe the 88 is fuel injected, while the 76 350 is carburated. So, what would be involved in that? Could I use the wiring harness from the 76, or would I need to adapt the 88 wiring harness?
I'm sure there are other things I haven't even considered, that's why I'm here.
The reason I'm looking into this is because my transmission went out in my 76 and it's a rust bucket. I found an 88 on CL with a blown head for $1k. I'm sure I can talk that down a bit. It's super clean on the inside (unlike mine), and has minimal rust from what I can tell from the pics. Regardless, it's definitely going to be less rust than mine. So, I figured for roughly the same price as replacing the transmission in my 76, I can just get a better rig and use my old engine.
BTW, I live in Texas if that matters for the swap. Thanks.
