rjpastor
350/350/203 w/part time kit and selectable hubs. Near new 35x12.50 15 Pro Comp Mud tires on black steel simulated beadlocks. New 4 in. lift. Engine and trans have been replaced by PO, unk miles, the engine is a Goodwrench replacement. Runs well, smokes a little but it appears to be from valve cover leaks. IT HAS PASSED LAST TWO SMOG TESTS. Trans fluid is clean and trans shifts well. Body has little rust, mostly surface, one small hole behind the driver side rear wheel well. Stock seats are complete, but need new covers. I also have two 89 Suburban buckets that I haven't installed.
I'm moving to AZ and my son who does most of the work (I'm too old and fat to be crawling around on the ground) isn't going with us and I can't afford to pay to have work done to finish it. Asking $3000
I can email pictures if needed - not quite sure how to do it here.
