I'm selling my '77 Blazer due to a lack of time to do what I want with it. I bought it a couple years ago with a 350 that needed rebuilt, so I put in a 400 like what it had when it was new. I'm not sure how many miles are on the 400, but I installed a reconditioned set of '71-'72 LT-1 heads, an Edelbrock intake and carb, and there is headers and dual exhaust. The oil pressure is a bit low when warm, but it is high enough to be safe. It may just be the gauge, as the car that the 400 came out of never had gauge readings that low.
The tranny is a Jasper th350 and shifts just fine. The 203 seems to work well and the shifter works how it should. The front axle is a 3.73 geared d44. The rear 12bolt currently has 3.08 gears in it, so that needs to be taken care of. The front shaft is currently out of the truck for this reason.
It has 4 inch front springs of unknown brand, they feel a little stiff, but not too bad. The rear is a block lift, and there is also a 3 inch body lift. Has 35x15.5x15 TSL SX's on the stock rally wheels. Tread on the rear is great, front looks a little less than half.
The body is pretty good compared to most around here. The usual rust in the lower areas, but nothing really bad. The rear floor seems pretty solid, and the tailgate sill functions, including the window. The interior is mostly black (never dyed the pass door panel yet) and there is S-10 buckets installed on a pair of 80's seat tracks. Has black carpeting and headliner.
There are a few things that need taken care of, besides the gearing in the rear. The rear main seal (2 piece) leaks pretty good, the tranny pan gasket leaks a little, and the heater blower does not work. The blower just needs a relay and fix the connector. Also, the rear tires could use some more BB's in them if you don't like shakes. Overall, the truck runs and drives well as-is. It goes straight down the road, and the brakes work fantastic. It feels a little doggy with the crap rear gearing, but it's really not that bad. I'm sure with a gear change it would have plenty of get up and go. That's all I can think of right now. The price is $1500 firm. When selling a vehicle, I don't like to do the "ask high, sell lower" thing. Thanks for looking.
good luck on the sale.
