Working on same "B-Pillar/Seatbelt Bold" area on mine. Cool to see you take everything apartStarted the prep work on the driver side donor quarter panel. It turns out there are bolts involved however the rear quarter panels are not simply "bolted in." The rear wheel wells are bolted in, sealed in place and tack welded too. Should be fun finding all the welds and cutting the sealant off.
I started today near the B-Pillar and cut out the floor in that section as well as the rear cab Mount. Lots of spot welds and lots of cramped spaces to get a cutter into. It went rather well and progress was made. Found the steel inside the quarter panel is a solid 90% rust free. Lots of flaky material but it is not rust. The lower edge will require some cutting and new panel welding but that's a bridge for another day.
My progress: https://ck5.com/forums/attachments/imgp6152-1-jpg.347659/More to follow, just got stuck recently with getting married, a deer hit my everyday drive vehicle (need to fix that first) and moving all my crap to the house with the new wife.
I am still waiting for the Tailgate Post and Tail Light bracket from LMC....it STILL IS NOT AVAILABLE.
I will post a new update tomorrow!
