58 apache
Well times here are tough. Just found out that Megans restauraunt she works at might be closing down. We live in a town of about 1200 people so jobs are few and far between.....anyway it leads us here
This truck is in awsome shape.
400 sbc that runs out great. lotsa new stuff. recent tune up including the valves.
sm465 with granny gear. new clutch less than 500 miles ago
np203 twin sticked and part time kit
12bolt rear.3.73's new brakes and wheel cylinders. lock right installed 2 months ago
44 front with flat top knuckels. 373's open.
kuhmo 35x12.5x15 on mickey thompson classics. perfect condition. maby 1500 miles if that. air soft bb's installed.
interior is perfect. many switches installed for adding lights etc. kick ass stereo with 2 10" boxes and an amp. alpine cd player. very loud. just installed cobra 29. sweet dash install. nees an antenna and mic clip. 2 fire extinguishers mounted on the floor. all guages and lights work. spedo needs a new cable. you can hear it spinning in the casing and the needle jumps around a lil. brand new tach. custom shotgun shell knobs door locks and lighter. rear slider. all 3 seatbelts.
body is in perfect shape. newer front fenders and inner fenders are perfect. bed is perfect not a ding or rust. it needs rockers which i have 2 brand new ones and 2 small floor patches and the drivers cab support which i also have. very claen truck for its age. bed is set up for dual tanks with a filler door in each fender but i only have one tank installed. needs a dash switch if you were to do the other tank. paint is 20 ft. a few chips and scratches.
it has a 2 1/2 - 3" lift on it now with blocks in the rear but i also have
all new never installed
diy shackle flip
2 sets of shackles for the rear 4" and 6" cross tied
stock length and 6" shackles for the rear of front
set of zero rates
all steel shims 3 deg and 6 deg
ext spring wrapped break lines
all new u bolts
new shocks
slightly used 6" front springs with poly bushings
new steering stablizer set up from copasetic to be picked up at the rti build
i know i am forgetting alot like the relay upgrade xj shaft new waterpump etc. but check out the build for complete details. I am negotiable but not alot. i will keep workin on her and update this as i go
http://www.carolinak5.com/forums/showthread.php?t=3502
contact at 434 374 0099 or [email protected] located in southern va zip 24529
ASKING 5500 OR OFFERS
diy shackle flip
set of zero rates
all new u bolts
new shocks
