I'm replacing the clutch pedal pivot hardware on my '77 which is very sloppy. The pedal is actually off my '79 which I swapped after buying it because of how sloppy it was. Now that I'm driving the '77 more, I bought hardware from LMC and putting it on this weekend. The problem is, what I have from LMC isn't any better than what I'm taking off.
LMC's part diagram
The bolt(9) dia. from LMC is .432", 7/16 nominal. The ID of the replacement sleeve(11) is .480. That's almost 50 thousandths difference, a huge gap between the two. I was expecting to see the sleeve ID more like .440 at the most. The brake pedal "feels" fine, no play or slop. If I had access to lathe still, I'd just turn my own sleeve, but that's not an option. Surely the clutch pedal isn't suppose to be this sloppy???
From the pic below, when this was on the '79 some owner let the pivot get really bad before doing something. But...the new sleeve and bolt isn't going to be any better.
The new bolt/sleeve
LMC's part diagram
The new bolt/sleeve
But I also recall that he used more bushings (I guess they just slip inside the tube?) as he felt it wasnt supported very well. May have been egged out too, and maybe bushings further in would mitigate that.
