Recently rebuilt my SBC 400 and replaced almost all of the attached accessories, including the power steering pump. When I did, I added an inline filter and an eternal cooler. Because of the location of the winch, I had to put the cooler somewhere else besides in the front of the radiator. I tried on the inner fender well but, that ended up being just above the resevoir and caused all kinds of problems. So I added the tube cooler just under the driver side door next to the frame rail where is was protected by the side step and a chunk of metal screen from work. The line goes from the outlet of the steering box to the cooler and then to the pump. I've tried to bleed the system the best I could by adding fluid as soon as it started howling and also by bleeding the system with the front end lifted off the ground and running the steering lock to lock at least 15 times and I STILL get a crapload of air back into the resevoir. Am I missing an O ring somewhere or a gasket? I have never had this much trouble with replacing a power steering pump before so any help is most greatly appeciated.
Joel
norcal
Joel
norcal
