Beater77
Registered Member
I have a 77 K5 blazer with a 350 in it. It ran fine started right up every time until my friends took it while I was outta town and ran it dry. So i hooked up some jumper cables and sprayed some starter fluid into the carb and it fires for a couple revs then dies. So I'm guessing gas isn't reaching the carburator. What do ya'll think I should do replace the fuel filter and if that doesn't work check out the pump? All suggestions are welcome I just want this thing up and runnin again, thanks.
