haha mine made it in stock form
I think accommodating a front dif from a GMT400 or newer truck is about the only "cheap" way to do 4x4 IFS.
If you look at the Colorado @Cili has, you will see. But seeing that he's broken it multiple times, I don't know that its a proven method.
Anyways, carry on. And post lots and lots and lots of pics![]()
Just a quick photo. It uses the front diff, knuckles, axle shafts, and brakes from a 2000 3/4 chevy truck. It has broke pretty much every time I've been out, but I think it's from the terrible suspension geometry that it has. Makes the cv axles bind and eventually rip a front diff mount or crack the case.
Edit. I wouldn't call it a prerunner either. I'm only getting about 10 inches of travel from the front before stuff starts to bind.
Cool bike!It will get routed down outside the frame under the cab and towards the rear of the truck. I don't think there will be a heat problem once the firewall is insulated and the headers get coated.
Worst case I will wrap the headers in heat wrap if they get to close to something. My bike is that way and you can touch the pipe without burning yourself.
Cool bike!
So, is the point of running the headers up instead of down just to give you more room down low? I've never seen that done before so I'm just curious about them.![]()
