[ QUOTE ]
All Chevy V8 motor mounts are the same after the mid '60s when they started using the normal clamshell motor mounts.
Yes your heads can swap over, any SBC head will bolt to any other SBC. The only restriction is trying to put big valve heads on a small bore motor, which doesn't apply to your setup.
Although you can swap the heads, I would drill the intake and use the heads that are on it first.
If you do choose to swap heads, put a set of valve seals in them while you're at it.
[/ QUOTE ]
1973 was first year for clamshell in trucks, and it doesnt matter anyways cuz the engine mounting bolt holes pattern is same since at least late 55 or early 56 and up, but blocks same 55-79 and then 80-86 and then 87-up
55-79 oil pans are diferent from 80-86 pans and 86-up crank snout is different from 85-down so fexplates and flywheels wont swap, the snouts look way different in 86-up for one piece rear seal, the are small and round instead of larger and flared and such like they always were
ut none of this matters, just use whatever flextplate or flywheel fits the engine and use correct starter and youll have it
