Fern
Registered Member
- Joined
- Mar 4, 2016
- Posts
- 65
- Reaction score
- 108
The early LS engines with the knock sensors in the valley plate had issues due to moisture getting past the rubber plug that was supposed to seal it off. The rust out and stop working. Not putting them in eliminates the the ECM's ability to retard timing due to pinging/pre-igntion.I know they tend to fail, only reason I was thinking of doing the delete.
. Will put new knock sensors and harness next and then install intake. Plan is to have the engine be able to crank by Saturday. Will start the truck wiring prob tomorrow or day after.I don't see why the O'Reilly sensors wouldn't work. But I've never used them since I work at a dealer, I just use AC Delco.Thanks everybody for the input. I had seen someone put rtv around the plug in a video. Seems like the best option. Anybody have good luck with O'Reilly sensors and harness? Or should I just source out the a/c delco replacements?
