MuzachMT
Registered Member
Hello,
I will start with useful information that may help in a diagnosis.
sbc 400, rebuilt 8k ago (not by me), bored 30 over, edelbrock 1406, edelbrock intake, hooker headers. Auto tranny, Idles at 1k in park, 6-700 in drive.
Problem: Recently I have noticed a knocking noise which seems to be coming from lower in the motor. Weird thing is that it is most noticeable in park, but also around 2k right before it shifts. It is pretty much unheard at idle while in drive. I bought this truck a couple of months ago already rebuilt so I don't know what cam, etc was used. All I have done to it is installed a fuel pressure regulator set at 5.5 psi, as that is what edelbrock says for the 1406 carb.
Another symptom that may or may not be related is a hesitation slightly after take-off (made a little better after the regulator).
I daily drive this thing about 2 miles each day, and need it to keep running ;P so any help would be greatly appreciated.
My mechanical knowledge and ability to do any major work is very limited, so I can't do any major troubleshooting, but any simple engine-in-truck ideas would be awesome!
**Pulled the inspection cover and the flexplate is fine, all bolts tight and not a single even hairline crack. Dammit. I was hoping that was it because now I can only expect it's a bearing..8k on a rebuild..must have been a lie or shoddy work!
. Thank you
