Had to replace a leaking caliper, leak is seeping from the plug on the piston so I went out to buy the caliper rather than rebuild one due to a time restraint on that Saturday.
First caliper blew a seal during bleed, replaced it with another one from O'Reilly's under warranty, then the banjo bolt doesn't get sufficient thread engagement. I gave up.
Sent it back then got a rebuild kit instead for the original caliper. Figured I would get instructions on how to take out the e-brake then pop the piston out. Found no instructions online....
So... Anybody got some step by step procedures to get me going? I don't want to ruin anything as I've never done a caliper with e-brake in them, only the fronts.
