78 ford drivers drop Dana 60s
mudboggink5
NEW JERSEY
Front is a high pinion drivers drop brand new Yukon 538 gears spiders are welded all new bearings 35 spline inner factory axle with new u joints and chomoly 35 spline outer shafts warn premium 35 spline hubs all new outer bearing new king rebuild kits brand new ballistic fab high steer arms brand new rotors and duel piston calipers with new pads* Missouri offroad diff cover 1/2 thick bottom has 1350 north west fab yoke also has stainless brake lines also comes with TNT customs 4 link full truss with coil buckets
Rear is ford Dana 60 new Yukon 538 gears Yukon full spool 1350 yoke ubolt style has 35 spline Yukon shafts I had the spindles bored out for the shafts Missouri offroad diff cover disc brake conversion all new rotors calipers pads and brake lines
I'm listing these for friend any questions he has all receipts call or text 973-600-1798 for pics
Located in south plainfield nj 07080
$2700 for both or will consider trades
