1978 Chevy K20. Originally a camper special. Truck is basically an off-road build but will still go down the highway at 70 without issue. Home built flatbed using the original bed floor so you can easily bolt a regular bed back on. If you want to build a nice truck you’d probably want to swap the cab as the current one has some rust and quite a few battle scars. Driver side has new rocker and floor pan and cab mount. Passenger side needs a rocker and the passenger B pillar has been massaged by a tree. Truck currently has a fairly worn set of 33s but will easily fit 37-38s. Frame is very clean, if you’re looking to build a crawler it’s a great start:
350 V8 with Holley carb
Turbo 400 trans
NP208 transfer case
14bff rear with 4.56s and Detroit locker
D60 front axle with 4.66s open
4” pro comp rear springs
4” zone off road front springs
Diy4x rear shock crossmember
RCI fuel cell mounted in bed toolbox
Ruffstuff rear disc brake conversion
Ruffstuff front and rear HD diff covers
ORD front and rear HD shackles
ORD extended brake lines
New steering box
Newer front axle joints
CFM fab winch cradle
Also included in the sale:
Original TH400/203 transfer case combo
Low mileage Vortec 350 from a 99 Tahoe
Two spare 208 transfer cases
Set of homemade half doors
Couple spare grilles I have
Asking $5500 on the gram and FB, would do better for a CK5er
This is what it looked like when I actually took it out and used it:
If you want more pics or info shoot me a text 814-592-1196
Turbo 400 trans
NP208 transfer case
New steering box
