How is the clearance to the #6 and #8 coils to the brake booster?
that side is odd.. even is passenger..How is the clearance to the #6 and #8 coils to the brake booster?
Let's try that again... How's the clearance to the back two cylinders on the drivers side to the Booster?that side is odd.. even is passenger..
Been dealing with dirtymax trucks at work, they are numbered backwards.
closest thing to brake booster is coil pack 5 and its 3 finger widths..
I used bolts. Plugs out installed from bottom. Switched to bolts after the third time pulling them off to change stuff lol
Same thing I clearance/coped my collectors an while at it put v bands on how'd you make oud with the primary clearing the frame?progress ...both headers in.
had to remove heat shield off of this guy.. what sensor is it and will i need it?
its in.. bloodied up a finger...
View attachment 363724 View attachment 363725 View attachment 363726
Primary tube on my passenger side was kinda close to the lower part of the frame, I'm sure just bc they were a generic stainless set of 1-3/4 headers.primary clearing frame? sorry not sure what that is lol..
hmmm vbands.. wonder if i can do that...
gotta put o2 sensors in too
