yup this was it. I was at 45psi!!!!Are you running a return style fuel rail or return less? The return style will have the pressure regulator on it that you can adjust, the return less won't.
If you do have the return style it needs to come up a lot.
now the issue.. i got it to 65psi as someone on fb said 55-65psi but his truck likes 68...
sovtook for a drive and stumble gone; however, I did not let it settle.. it actually settled at 72psi!!!! and was chocking itself...
now the engine is from saty west virginia... and adjustment screw was rusty..it stripped going up and I managed to work it back down to 58psi...havent driven it but should be good...
