I currently have my buddy's 78 K5 because he had me replace the rear u joints. While I have it I was gonna see if yall could give me some insight on what might be causing some of the other problems it has. 1- the speedometer doesn't really work, the needle is always bouncing around and when you hit 50mph it pegs out a little past 100. 2- when you shift into reverse there is about a 5-6 second delay before it actually goes into reverse. Shifting to drive doesn't do it, it shifts fine, it's just reverse that has the delay. Any ideas? The tranny is a th350 and if matters-the truck is a 78 k5 Cheyenne so it's got all the options.
