79general
Registered Member
my truck is a 79 K10 with a dana 44 in the front. it is having a steering issue that just popped up and i have now clew what could be causing it, im at a loss... kinda. the symptoms are almost like something is loose but nothing is. some times, not all the time (seems to happen more when the truck and the weather is warm) there is a delay in the steering when turing. ill turn the wheel and the truck will start to turn but not as much as it should then all of the sudden it will pull hard or veer in the direction im turning. this is a problem when on long slow bends because the truck will veer hard and when i correct the direction of the truck and i veer hard the other way... sketchy. on the free way some times the truck drives just fine but other times it just wont go straight and it is constantly trying to veer one way or the other its not happy going straight is almost like but not quite like im on a mound or in ruts. i think it could be the steering box but not sure. i flushed out the PS fluid and there was some ATF in there it looked like a mix of ATF and PS fluid. i replaced it with PS fluid it helped some but it still dose it, that is what makes me think it could be the steering box but, i really am just guessing and have no real idea what could be going on. every thing seems tight linkages, ball joints, steering column the one thing i have not had time to do is put it on a jack and see if there is any play in the tires toe in and toe out i dont think so because i replaced the hubs like a month ago and i would have noticed it then... i think. any ideas folks???
