If anybody is even reading this far sorry the build is scattered. Life has been scattered catching up after a move. This thing is down at the moment, it gets pushed into the shop on Friday evenings and I work on it Saturdays then push it out. I may be able to have it running again soon. But once I started to install parts it sorta snowballed into adding more stuff.
I still need to wire up the TBI and plumb fuel lines and hoses from the tank. My initial start up of my fresh EFI swap will also have a 30 min cam break in. I went with an edelbrock 2102 cam, pretty mild. Cannot wait for this truck to be running again. I have all my parts to build my 14BFF and Dana 60 then install. But I will not install them until they are fully built and can just be installed.
I did recently acquire a 5.3L core from a 2014 truck for free. So I could build that on the side later for an install if I want.
The axles will not be special or anything new but will have the following below.
Dana 60 front-Yukon 5.13 gears and spartan locker. New brakes. High steer cross over arms. Hydro assist ram.
14 Bolt rear-5.13 Yukon gears and Yukon Grizzly locker. New brakes. New 1350 yoke.
