noclrnce
Registered Member
I sprayed this truck in PPG tintable primer so it can still be painted. I put a new hood and both fenders on last summer, but the hood is already starting to buckle. The truck has new rocker panels on but they need to be finished and i replaced the wheel arches on the bed also. Rocker area and inside bed has been sprayed with Gator Guard bed liner with a rubber bed mat. Has a chrome roll bar but its rusty. I also have a set of black Carr hoop steps for it still in the box. Has air horn on roof and air tank under the bed, but needs an air compressor to make it work. 1 ton running gear. D44 full floater front 14 bolt full floater rear. Suspension is a 12" Genuine Suspension from 4 Wheel Parts. Truck also has a 3" body lift. Rebuilt driveshafts front and rear. Transfer case is full time. Brand new GM crate engine with Edelbrock intake manifold with Hedman hedders and new exhaust. Recent tune up (plugs wires cap rotor) with a vaccum advance kit, new water pump. Rebuilt TH350 transmission 2 years ago. 15x39.5x15 TRXUS tires. Wheels are kinda rusty but can be cleaned up and painted. Check out http://www.mautofied.com/listing-100058062.htm for pics
