79 k5 in IL
BIGRAT
Registered Member
Chicago
thinking about selling my blazer, 454bbc th350 with np208. motor has about 1000 miles on it, drive train rebuilt when motor was swapped added a shift kit and stall. motor has srp pistons, com cams healty cam, push rods and lifters. body is real clean rockers being the worst spot.
also have 1 ton axels(78-79 ford high pinion reverse cut front axel) for it 4.56 gears locked in rear and complete sm465 with np205 t-case. all I needed was a ford np 205 for the doubler setup.
thanks for looking call me if you have any questions 708-217-9700
6000.00 obo for the truck, with everything id like to see 8500.00. i also have a new 8" skyjacker lift kit minus the shocks.
the motor is a 454 oval port heads, comp cams (bigger cam), pushrods and lifters. tourqer 2 intake, holly 750 double pumper ultra, new gm performance parts vacuum dist. motor has less than 1000 miles.
trucks got 76*** miles on her, there is no ac but heat is back and working with the ac delete box.
