ladybugblazer
Registered Member
The current setup in my 79 I have the "wing" style ignition cylinder in my steering column like this:
However it turns on without the key and I want to get a new switch to get this fixed. It is setup with a tilt steering column. For some reason the ignition cylinder that rockauto recommends and other websites I've seen on is the GM Part # D1499A which seems to be panel mounted and doesn't have the "wings":
Images of all the 79 K5 Blazers I've seen on the net they all seemed to be in the steering column and with "wings" so I'm confused on which part to get. I want to try and get the GM/AC Delco part if possible. I've seen this one on amazon which looks like it may be the right part but there is no confirmation from any of the vehicle filters:
If anybody knows which one it's one of you guys! Thanks
