79 scottsdale have stock lockers?
chazawazzle
Newbie
spokane valley, WA
hello all, its been a long time since ive been online but i was wondering if my 79 scottsdale has lockers front and rear. it has a shifter that says hi loc and lo loc and the transfer case instructions on my visor are very old and worn out and i cant read them. any help?
chaz
it shouldn't be. when you turn is it difficult to turn? that would be in 4x4. with the np203 and auto hubs you just dont have to lock in hubs to put it in 4. you should be able to select 2wd on the shifter
yes, it is always hard to turn and it hops just like its in 4x4 and i cannot do donuts. i might be wrong about the 203 transfer case, but the shifter has the option of lo loc, lo, neutral, hi and hi loc.
I have a 1979 pickup with open diffs and a NP203, in 4wd it corners funny.
there is no 2 hi option? maybe someone else will know more?
The 203 t case is full time four wheel drive and it has a lock and not lock mode basically. The lock mode puts equal power to the front and rear, it has nothing to do with lockers in the axles. It works just like any other t case in that scenario.
The only part thats really special about a 203 is that there is an"unlock", or differential in the transfer case. This is what allows it to be full time in the street.
That's the reason the 203 only lasted through part of the 70's. On road gains were "meh" and the decreased gas mileage and increased parts wear weren't popular. Especially given that was when gas prices first went up and the rise of the EPA muffled power.
For the record they had drive flanges and not auto hubs like the 80's trucks. The part time kits put manual hubs on axles and converted the t-case so 4hi functioned as 2hi basically.
The function of a stock 203 is well described above. There are/were many companies that sold "part time conversion kits" for the 203 and therefore a lot of these trucks running around with converted 203's that allow 2wd.
In my opinion the 203 got a bad rap. Everybody says how horrible the full-time 4wd function of it was, but then look at all of the full-time 4wd vehicles on the market through the '90's to current.
I grew up in a farming community and when I was a kid it seemed like everybody had a late-70's Chevy K20 with a 203 t-case. Granted, they would wear out the u-joints on the front driveshafts but not any faster than the rear driveshaft joints so I guess they did cause more wear than a part-time truck. They did have better traction in the regular 4 hi mode than a 2wd truck as the farmers were alway pulling wagons out of fields. Still remember my older cousin who I helped bale hay through high school. They had an old '79 with the 203 and a new "at the time" '88. They never touched the t-case lever on the '79 but almost always had to shift into 4wd on the '88 to pull wagons out of the field. The 4-low unlocked position was really nice to for pulling really heavy wagons out on the road.
They were fantastic for commercial plowing too.
