I’ll start by saying I’ve spent the past few days researching this. I’m aware of the facts, so at this point I’m looking more for opinions considering this is in a K5 not the stock application.
Have a 91’ K5 with 8.1, 4L85, 5.13s and 37” tires. My end goal for the truck is to maintain the Offroad ability, but it eventually endeavor on cross country trips, so good highway manners are a must.
Going off the .75 OD found in the 4L85 as well as the tach, here are some numbers
65MPH - 2270
70MPH - 2450
75MPH - 2620
Not too far off from the same setup in Avalanche/Suburban with 8.1 w/4.10 option
65MPH - 2240
70MPH - 2410
75MPH - 2580
Pretty similar especially when you take unit account the larger rolling mass of the 37s
However 4.10s was for towing in the 8-10k range, something I don’t plan on doing in the K5.
Fuel consumption aside, am I chasing my tail considering swapping in lower gears for a few hundred RPM? The intent is to be able to cruise at 70-75 for 6-10 hours without issues.
I don’t want to swap any larger tire then a 37” since it seems to have the most tread options verses the mainly MT tread when you go any > 37” diameter.
Leave it be, nice quiet exhaust, set cruise for 70 and go? Or tear apart some axles ?
Thanks in advance
65MPH - 2270
70MPH - 2450
75MPH - 2620
65MPH - 2240
70MPH - 2410
75MPH - 2580
Thanks in advance
