Both the 496 and the 502 are called an 8.1 liter.
That's not true, the Gen VI 502s have 8.2L cast right into the block.
Someone will correct me if I'm wrong, the 496's in late model trucks is an LS based engine where as the 502's are a classic BB design.
This appears to be true if you look at the top of the engine and see the coil on plug ignition and the funny intake, but that is where the similarities end. The block is based on the tall deck big block, but with some changes. It has provisions for the crank sensor in the rear, factory oil cooler ports, the head bolt pattern is different for some of the bolts, (many are the same location), dual motor mounts, etc. But it is far from an LS engine, not even close.
