Parting Out 8.1 Liter parts
BoondocK5
Chevrolet Bone Collector
Author
Salt Lake City, Utah
Front coolant crossover pipe $25
Crank pulley, big truck version $50
8.1 exhaust manifolds LH & RH $150
8.1 timing chain cover w/ Long style cam sensor $100
8.1 2004 model ignition coil packs, set of 8, $200
8.1 2004 heavy duty truck crank pulley(long version) $150
8.1 2004 injector harness, $100
8.1 2004 ignition coil harnesses LH & RH $100
8.1 2004 drive by wire throttle body
$200
8.1 2004 aluminum valve covers LH & RH
$100
8.1 2004 Aluminum BIG TRUCK 13 quart oil pan. $150
8.1 2004 Intake manifold, big truck versions, factory EGR block off plate, single point fuel rail(no return line) 8 factory injectors, $350
You know the deal, shipping on your dime. Located in SLC, UT
