Ok so I am keeping DBW and ran into a few snafus...
1. pedal ASP130 - 1994-2000 k3500 direct bolt in pedal assembly
2. 2001 TAC Module
3. 2004 TAC to pedal cable.
Now.. I have the 2001 Plug to pedal. apparently guy i got motor and harness from just cut it vs putt lot of firewall to give full plug.
Issue 1
04 and 01 Pedal plug are the same, got a groove on right...
Pedal has groove on left.. ok i bought a pigtail when i bought pedal and it is the right one...
Issue 1 leads to issue 2...
04 harness has 6 wires...
01 harness has 9 wires...
so if i use pigtail... im guessing 9 wires...
Is it a straight through cable? need to know pinouts on each end...
Ideas?
2. 2001 TAC Module
Issue 1
Ideas?
