8.1L propane to gas conversion
eodcoduto
We could have been closer.
Muscle Shoals, AL
I didn't want to add more to the 8.1 sticky, but I have found a couple 8.1 propane engines that are cheaper than the gassers. Other than fuel rails and injectors what needs to be swapped on these to run gas?
??? Seen them new at the propane trade show . .not sure if compression ratio??
Propane fuel is 110 - 120 octane
never had a propane setup 8.1 .
but what i have heard is injectors / fuel rail and pcm . then its back to gas motor .
today i became a member of the 8.1L club. orignaly from a c6500 truck feed by ng/propane?
Just figured that if you had gotten that engine with no heads running (on gas), then you've already answered the question.
oh ya that motor . it was just a long block nothing else on it .
funny we talk about it as i need to dig it out for the 02 3500-HD i have now with a bad 8.1 in it .
