8.5 gear sets
punched355
Registered Member
canada
Just a quick question, whats the differance bettween front and rear 10 bolt gear sets other than the bearing kit or are they the same?
Even the carrier and pinion bearings should be the same. You can swap the carriers, ring and pinion, spider gears, shims, etc. between the front and the rear.
