I've got a pair of 6" Skyjacker fronts with 1" zero rates that have 4 degrees taper milled into them. The thinnest part of the zero rate is a true 1" thick to make the lift a true 7".
I also have 38" radial Swampers with lots of tread left. But these tires are 15" wide and fit 16.5" wheels.
