8 inch lift tires rub
desvik3
Registered Member
el paso,tx
I Installed a superlift 8 inch lift all springs currently running 35 inch tires on 14 inch wide rim getting olot of rubbing while off roading specially if my tires are turned
I had a blazer with 8 inch lift and 35 swampers and had to trim the rear of the front fenders because of contact under full compression
I'd say the 14 inch wide wheels aren't helping the clearance any. Unless there's a ton of backspace.
Probably a combination of really wide tires and backspacing that's just plain wrong...
Ok I have a brand new set of 38 x15x18 nitto mud grapplrs the widest rim i found in size 18 was 9.5 inches so i ask for 4 inches of backs spacing correct
