74Blaze
Registered Member
whats up guys I am going to be lifting my blazer 8" pretty soon will I need to clock my front axle? I am running a th350 and np203 t case.
I want to clear my 40" tires and yes I am going to go with crossover steering.Why 8" its gonna be stiff as hell and your steering will suck unless you go crossover
I want to clear my 40s I know with 8" I will have to trim my body also i am going to go with crossover steering and I am aware that my driveline will need to be extended my overall purpose with this truck is to highway mud and sand.Most people on here don't just lift the truck, without a reason. Usually it's to clear tires or make room for more suspension travel. 8" is a lot of lift.
To answer your question, yes there's a possibility you'll have problems w/ the driveline angle at that height. Chances are you're running a cv type front shaft and you need to have the pinion pointed at the t-case more or less. You'll also have to extend it as the shaft won't be long enough. If you have to rotate it too far you'll may need to reclock the C's on the end to keep the caster under control.
Also, the steering on these truck gets kinda funky when you lift them because it's all on the one side and the angle on the draglink gets more vertical. You loose the ability to turn the truck full left/right.
What's your overall purpose with this truck
My blazer currently has a 4" shackle flip kit in the rear if I do a 2" spring lift will that push my axle fwd?o.k. here is my input on a blazer with 8" of lift and mud/highway use/trails .
yep do crossover
yes driveline work will be required. and don't be surprised if you need custom shaft or shafts . the angles are going to be steep .
do NOT drop the transfer case crossmember yes it makes the rear angle better but the front angle worse . also if not done correctly will blow out the frame rail lip it bolts to .
if me I would do this combo .
4" suspension with 1" zero rate to move axle forward in the front . gets you 5" lift and lots of firewall clearance you will be needing . keeps trimming down on the body .
4" flip kit in the rear and a set of 2" lift springs . this will get you the lift in the rear plus 1" to level it out a bit from the rear low it prob has now. this will also require pinion angle reset with shims . or best way do new perches with the off set center pin holes to set angle and weld on inplace of stock tubes . also gets you the ability to move the axle back 1" and this little bit might help in driveline angles and shaft length to your advantage.
next and some may say yes/no but 2" or 3" body lift I prefer 2" dosnt look as goofy as a 3" . and also a new set of poly body mounts since your in there . as your rubber ones will be worn out from age and wear and tear .
this would get you a real good ride / flexy suspension / room to work on stuff / clear the 40" tires .
and what ever you do do not waste your money on rough country lifts . there springs are DUMP truck stiff . . . .
do your home work hear on ck5 as we have covered this a lot and helped people do it right with off the self parts and custom stuff . also helped a lot of people fix first time goof ups.
I plan on mostly driving my truck on the road and doing mild off roading not gonna be going too crazy.
Not so much a sky high look just want to clear my tires with some fender trimming don't wanna go too high.
