8 lug axle conversion
chvymudin3388
orange grove ,tx
im looking for the easiest cheapest way to go to 8 lugs i was wondering if 12 bolts came in 8 lug? i want stronger axles and of course theres nothing like the look of 8 bolts holding on youre wheels :D
Cheaper to put a 14BFF in back.
Up front, switch outers from an 8-lug D44 or 10-bolt, they're identical parts.
-- A
12 bolt didn't come 8 lug, its only marginally stronger than a 10 bolt anyway.
-- A
sorry but by outers what all are you talking bout from the spindle out or what?
yeah youd need caliper backing plate, hubs, and rotors
slightly incorrect in the case of my 88. before my 60 up front i went to 8 lug outers, etc. i didnt need to change calipers. my calipers worked i just had to grind a small little tab on the caliper so it would clear the 3/4 ton backing plate. shouldnt need new calipers.
Yeah, the whether-you-need-calipers depends on brake lines more than 6- or 8- lug. In my case I was going from a '74 D44 to a 10-bolt, so I had to switch lines or calipers. If you're going from a later D44, I think, you're okay.
-- A
actually im thinking of going out getting the 14 bolt and finding a d 60 front cause i want strength to not a stock 1/2 ton front with 8 lug outers so yea
