8-lug outers, 10b gears
fryed_1
Virginia
5.13's for 10b - $125 plus the ride. Includes install kit, slightly used but great shape
8-lug outers, ready to bolt up, supply your own rotors - $50
warn premiums with outers pulled from an 84 d44 (around that year). Includes hubs, lockouts and backing plates. Rotors are fairly trashed, so no since in sending them along if they'll need to be replaced anyways. They're bolted up to a 10b now.
So you have the spindles for them too? I'd need the spindles to make them work for my '72 D44. Could you get me a shipped price? I wouldn't need the premiums as I have a set of them already. What can you do? Thanks
Hoby
I don't have d44 spindles. I have 10b spindles with the D44 outers on them.
I suppose I could pull them and ship, I don't know for a fact if they're a direct swap, but they might be since the outers are between D44 and 10b.
im interested in the outers?
90 k5 wiht a 10b. theyll bolt on?
Yes. Supply rotors and pads and they will bolt right up, backing plates, hubs and lockouts all. They were original off a D44 and bolted right on to my 10b without any problem.
I estimated 40lbs or so on a 20x20x10 box (probably less) and it was about $17 for ground shipping, $58 for 2-day, through DHL. So figure that into $50 plus whatever you want for shipping.
I'm putting the truck on the trailer this weekend, so won't be ship them out, at the earliest, until monday.
give big_blzn until tomorrow to reply since he inquired first, otherwise yes, they're yours.
alright sounds good. just lemme make sure i got the funds around to do so. pretty sure i do.
hey man im gonna have ta back out on the outers. some things just came up and i really cant afford to spend the money right now.
srry man
Hey Did You Sell Those Outers Yet, I Have An 85 K5 With 10bolt On The Front And Want To Match Up The 8 Lugs In The Rear, Will They Work.
so are you saying you have everything except the rotors ?
these are external hubs ?
still available? how much shipped to 93551?
want to put on my 81 K5 w/ 10 bolt 8.5" front, will it bolt on?
what rotors will I need? any 84 gm truck w/ 8 lug d44 front?
thanks
10 bolt spindles are a direct swap onto a D44. 77-up all D44 and 10B axles used the same knuckle, spindles, hubs, stubs ect.
To put the new style parts on a '76 and down axles you need everything including the bearing hub, spindle, and stub shaft. Also backing plates if switching from 6 to 8 lug.
thanks
All 8 lug 3/4 ton rotors from '73-87 are the same I believe. There were no D44 axles in '84 on Chevy trucks though. It was most likely swapped in from an older truck. '77-80 were the last years of the D44 as they used up the stock on hand and then switched over to the 10 bolt.
