8 lug rim compatability
only 31s
mass
just got the 410 axles, 8 lug rims on 16.5 wagon wheels-can you guys give me info [if any]on any other compatable rims for these-maybe dodge-ford ??just want to know what could fit incase i found a good deal! Thanks for any info
I believe all the early 70-90 8 lugs will work, all are 8 on 6.5 bolt circle...the later Fords have changed but Dodge would still fit into the 90's.
every 8 lug wheel will "fit" unless it came from a 99 or newer superduty
it will fit but theres alot of other factors in how well it works.
As long as it's an 8 on 6.5 bolt circle AND the center hole will clear the wheel hub they will work, doesn't matter what make of vehicle.
