mwood1985
ok im a little overwhelmed here. ive got a of 38s for 16s cheap so its time to pull the trigger on a 14bolt swap.http://coloradok5.com/axleswap.shtml this writeup makes it seem like its a bolt in swap in the rear with no modifications other than driveshaft ujoint differences id like to use a full float 10.5 14 bolt for the rear and swap my front 10 bolt 6 lug hubs for 3/4 ton 8 lugs. I got the front parts figured out. what I need is info on what truck carried a ff 14 bolt that bolts up spring perches and shock mounts wise to a K5. my two best friends have a 76 K20 and a 85 both owned since new. the 76 has a full float an the 85 has a 9.5 semi float 14. from what ive read the 3/4 ton pickups and suburbans may have had both types over the years. i search for on car-part.com to find junkyards near me so im not wasting my time hunting for something not there. what years should i look for to get a bolt in swap 14 bolt full float? i cant put my k5 down for longer than a day to have someone weld on shock mounts ect because its the daily driver at the moment
I would also hate to mention that mine came from a '78 K20, but have you scope one out and find it different.
Which happens with old vehicles anyway.
Or was that a C20 Burb. LOL, relying on memory
