8 on 6.5 3" wheel spacers
bad larry
USVI/Maine/NYC
Wanted: 4 3" 8 on 6.5 steel hubcentric wheel spacers. I would consider 3.5"ers and would consider 6061 aluminum, lemmie know what you got.. Thanx! I'm posting here to try and save a little $$$ from new....
I have a set of spacers that are 3 1/8" thick - they are steel, have 5/8" studs and made by Arrowcraft. One spacer has one bad stud and I do not have a complete set of nuts (nothing special, just 5/8" fine thread). They are NOT hub centric.
Here's the trick, these have about 1/4" or so of bare shoulder sticking out of the spacer before the threads start (or end) - presumably this is because they were intended to have the thickness of 2 wheels on it. I tried to use these on my H1's but the nuts bottomed out before the wheel was tight. I tried knocking a stud out to find something that would work but never did.
Hey! thank you very much unfortunatly not quite what I'm looking for. I've actually changed my mind and Ideally need one set of 2.5"ers and one set of 2"ers although 4 of one or the other would work. If your wondering this is kinda where I want to be space wize, not my truck but exact same thing down to the year course I got 3.5" of lift and soon zero rates...
http://www.pirate4x4.com/forum/showthread.php?t=917101
