80 K20
1967k10
Nebraska looking for D60's
80 K20 4x4. Has about 40K on Tonawanda 454. 4spd/205. 6" lift,35" tires on 16.5" alluminum rims. Tires aren't super. Body is rough but would make a great wheeling rig.
$1200obo
Edit: needs a throughout bearing. Just forgot to mention that.
would it make a trip to pa? 10B front and 14BFF rear? hows the rust on the cab and is it a block lift or all spring lift? will the truck still move even though it needs a throwout bearing? wheres the worst of the rust at and hows the body mounts?
10bolt front, 14FF rear. Cab is fairly rusty. Lift blocks in the rear. I haven't driven it since the throwout bearing went bad. It belongs to my buddys brother and he's trading it to me for a 2wd truck I have that will get him back and forth to work on lesss fuel till he can afford a new one. Apparently he doesn't want to fix the bearing,which is what I'd do.
Not sure I'd drive it 2000mi. It's plenty reliable I think but I personally wouldn't drive a 28yr old truck that far.For one a big block isn't going to get more than about 14mpg on a good day. Just my openion though.
how far east could you get it? Im in Sikeston MO
If someone wanted a cool project I'll include a crew cab and clip and a 5' flatbed for an extra $750. That would make a perfect crew short bed wheeling rig.
Was somewhat interested in the truck due to location. Very interested in the crew cab. Is it a whole truck or just cab? 4wd? I think i'm just a few hours nw of you so driving down with a trailer would be doable. i've been busy with the weather but drop me an email or reply on this thread.
thanks
mike
I was just listing the cab off the crew cab. I still have the truck semi together but no drivetrain in it. Just axles under it. D60/14bolt with posi. They are pending sale but not sold for sure.
I'm south of Gordon.
thanks
mike
any pics? what do you want for whats left of it? i have a motor trans t case. i'm looking for it to have frame, cab ,axles and maybe a title.
edit:found it under axles section. hard to tell from the pics are the rockers damaged or just the doors and does it have a box or flatbed or nothing behind cab?
