81 1-Ton w/Trailer
kgblazerfive
keymaster
Hooper, Utah 84315
81 1-Ton dually runs good 454, propane or gas, new tires all six, hydro boost leaks and has exhaust leak. Have headers for it, stock radio, minimal rust, a/c and cruise work, interior ok, seat has some tears in it. Dual batts, trailer brake w/pwr to trailer,
32 +/- foot goose neck triple axle all with brakes, bed is 28ft has batt and winch.
I will seperate but trailer only, wont sell truck without selling trailer but will sell trailer without truck.
I want $2800 For truck and $2300 for trailer or $5000 for both.
How much will that big block pull? You think the trailer would handle a good size backhoe? Is the propane to gas switch done with a electric solenoid or just a manual ball valve? Thanks.
Not sure the trailer would handle a good sized backhoe but know where one is that will. The trailer is made from a travel trailer frame with a third axel added to it I'm guessing that the axels are 3500 each. So a backhoe would be a little heavy.The truck would have no problem pulling it. The propane is switched with both a soleniod turns aff the gas and a push, pull lever opens or closes the air cleaner. In the pics its the thing right next to the brake control.
