81-87 cab, 73-80 front clip: Interchangeable?
madmike
ohio
I have a chance to pick up a 1985 or so cab in good shape, but I already have a 1973-80 entire front clip. I know that in the region of the cowl, the 81-87 cab hood hinges slip in holes, instead of bolting to the front fenders on 73-80. I've seen an article or two on bolting the 81-87 front clips on earlier style cabs, but not vice versa.
My question is: Does the 73-80 front clip bolt on the 81-87 cab, and if not, what modifications are necessary?
Thanks for any advice! /forums/images/graemlins/smirk.gif
I had a truck that had the 73-79 front clip with an 81 cab. I bought it like that so I don't know for sure what is involved with the switch over. It looks like all that needs done though is to remove the metal cowl around the windshield wipers and bolt it on.
the 80 and older cabs have hex head studs (for lack of better terms) that pull the back of the hood down as it closes. if you dont that them, you most likely will never get a good fender to hood body line. if its just a wheeling rig thats going in the bush, i wouldnt work a bit about it.
