81-87 chevy truck exterior parts ans others
bot0611
Chula Vista, Ca
Fender embles (silverado 10)$10 pair
Lower grille molding (upper and lower) $15
Rear upper moldings LH and RH (with bowtie) $25 pair
Center molding $20
Headlight bezels with trim (LH and RH) $10 pair
Outter door handles (LH and RH) $15
Head light reainet (2) for the 4 headlight set up $5
ALso have the following:
Dual gas tank selector valve (as-is) $15
Carb spacer (phenolic plastic, 1/2") $10
Carb adapter (1") $10
Power windows legulators (LH and RH)$30
RH and LH power window motors (RH needs fixing, LH works buts a
bit slow) $30
Speaker spacers (6x9's, 1-1/2" height) $15
Headlight switch $10
Interior trim (Rear window side moldings, rear window upper molding, interior upper window molding, windshield inner window
moldings) all for $40
Leaf spring, from a set of Skyjacker 6 inch front lift (one leaf per side, add a leaf) $40
Camsahaft (performance, got it when i bought a rebuild kit for my 350 SB, with lifters) $40
Graphic equalizer $20
Chrome valve covers with blue insert, i was told they are for SB chevys but in not sure, i put them on and had leakes, ill be happy to give you guys some meassuments $35
Pricing plus shipping.
Thanks.
Forgot to mention:
If theres something else you may need let me know this thing mught have it (theres no engine, tranny or tc parts)
