I picked up an 81 GMC K 2500 that’s pretty much all stock and un-butchered , but anyway the fuel pump was bad and while shopping around I could only find a fuel pump with a inlet and outlet port and a return, the one that came off only has inlet and outlet and no return, the truck has no return line installed. It is a dual tank with the selector valve, the selector valve appears to have a return port that is capped off, Would this be a sufficient place to install a return line and if so where would the fuel return to, it does not seem to be plumbed to the tank?
Looking between the cab and bed I can see the top of fuel module that seems to have either a vent line or return that is capped off but would require dropping the tank to acces it, Can anyone enlighten me the best way to approach this? right now I just got the return on pump capped off but I don’t want to over pressure my already pos quadrajet
