Jason Thompson
Registered Member
- Joined
- Nov 22, 2017
- Posts
- 17
- Reaction score
- 3
I need some help with pinging. I have a 400 sbc in has a COMP Cams Xtreme Energy 4x4 Cam
Duration 270/278, Lift .480/.498. It is Edelbrock 1806 Carburetor, Thunder AVS, 650 cfm. The heads are also Edelbrock 60899 aluminum 64cc chamber and the intake is Edelbrock RPM air-gap no egr valve. The compression ratio is 10.5 to 1. I run a MSD street fire HEI distributor with MSD 6al box. The only gas I put in it is 91 octane premium and thats the highest octane the have around in Peoria, AZ (N.W. Phoenix). I have run 100 octane racing fuel 10 gallons and that eliminated the ping but I can't afford to do that all the time or octane booster every fill up! My mechanic thinks increasing the jetting will help the pinging. Oh also I have advanced the timing quite a bit to stop pinging but I do still hear it at times. Im thinking the air/fuel is running lean. My question is can re-jetting the carb to increase fuel help the pinging? What would you guys recommend? Also, my valve lifters are 1.5 ratio and I was thinking of changing them to 1.6 to increase air/fuel. Please, let me know what you all think. I will start off with the jetting then maybe move to valve lifters and if that doesn't work maybe change the cam or heads! I'm frustrated and hope someone might help me out that had same situation! I think COMP CAMS recommended a cam that might not be producing enough air/fuel, however, I'm fairly new to a lot of this and don't know crap! I told Comp Cams all the information on the 400 sbc(the specs) and the recommended this cam! Like I said I'm a noob who doesn't know SH!T. Or if someone knows a good shop that could dial in air/fuel ratio and eliminate the ping would be awesome! So frustrated with the mechanics I've been dealing with lately. Thanks for any input!
). Yes I'm using recommended plugs. The Blazer has returned and after installation of bigger jets in Edelbrock 650 carb. the pinging has went bye bye. I plan on installing a AFR gauge soon and then I can really dial it in to 14 to 1 ratio. The weather has cooled off quite a bit recently, so I hope the pinging doesn't come back in summer(when it gets hot out here in AZ).
