four50NCalif
Registered Member
So I was getting some grinding noises coming from the front while the 4 wheel was engaged, turned out to be the front driveshaft hitting the trans crossmember. I thought it was just bad rubber mounts but upon further inspection, one of the legs on the trans adapter has broken clean off where it mounts to the rubber on the crossmember. I have found that I can probably get a used one online but how hard are they to install? do you have to drop the transfer case? can you support the transfer case and trans and bolt it in?
